Commercial use of longitude and latitude (Geocoding by ESRI)
3225
03-05-2020 11:40 PM
micheleburgalossi
Hello, I would like to ask a question about the commercial use of the geocoding results through the Esri Arcmap / ArcGis Pro tool/API.
I would like to create for the company I work for an address database with the relative coordinates (longitude, latitude) that I obtain through geocoding processes with Esri.
I would like to insert this database of coordinates in a software (geocoder) to resell to customers: is it possible?
I couldn't find anything by reading the Esri TOS.
Any suggestions are welcome. Thank you! Michele
DiegoLlamas
Hello, Would you able to do this, did you find information about this?
DerekLaw
Esri Esteemed Contributor
Hi Michele and Diego,
> I would like to ask a question about the commercial use of the geocoding results through the Esri Arcmap / ArcGis Pro tool/API. ... I would like to insert this database of coordinates in a software (geocoder) to resell to customers: is it possible?
These types of licensing questions should be taken offline. Please contact Esri Customer Service,
Contact Us
@Diego - Please work with the Distributor team.
Hope this helps,
JohnPreysner
Hello michele burgalossi and Diego Llamas‌ - this type of use is NOT permitted.
