So glad to share another success story at the Miami International Airport (MIA)-powered by the great GIS team in the Communications and IT Department (CITD) of Miami-Dade County.
The GIS team, a long standing Esri Advantage Program customer, supports the airport organization with software and GIS expertise. The team is highlighted in this short video on how Jenny worked on the Airfield Lighting Torque Check workflow and Monica's work on the Grease Trap Inspection Program workflow. Both powered by mobile/field tools and informative ArcGIS Dashboards. During this journey, Esri Professional Services provided some best practices and Tips and Tricks on deploying standardized, branded, information products using Arcade and HTML.
Airfield Torque Lighting Solution
Grease Traps Solution
We talked a lot about this very specific torque wrench, and you can see it in use in the video. The calibrated reading is supported by Bluetooth connection to the device to capture and annotate the reading at that particular asset.
I hope you have two minutes to watch this YouTube video and share your comments.
