Split intersecting line arcade error
1211
05-26-2021 12:57 AM
alejandroDimas
Hello!
I am using this attribute rule (split intersecting line):
https://github.com/MikeMillerGIS/arcade-expressions/blob/master/attribute_rule_calculation/SplitInte...
But when i insert a point i get this error: "GlobalID: The field is not editable"
Any ideas?
Thanks
JohannesLindner
Towards the end of the script, they set the GlobalID of new features. GlobalID is not editable by the user, so that doesn't work. Try commenting out the lines that say " 'globalID': GUID() ".
 if (polyline_1_length > polyline_2_length) {
        update_features[Count(update_features)] = {
            'globalID': line_feature.globalID,
            'geometry': polyline_1
        new_features[Count(new_features)] =
//                'globalID': GUID(),
                'geometry': polyline_2,
                'attributes': pop_keys(line_att, keys)
    } else {
                'geometry': polyline_1,
Have a great day!
Johannes
alejandroDimas
Thank you Johannes!
I tried that but the same error appears.
The matter is that if I use this geodatabase (https://github.com/MikeMillerGIS/arcade-expressions/blob/master/attribute_rule_calculation/SplitInte...) it works, but if I use my own geodatabse it doesn't work
Thanks!
