This is my system configuration:
- Arcgis Enterprise 10.8.1
- Arcgis Pro 2.9.1
- Utility Network version 4
I'm trying to delete multiple records from a related table using Arcade. My plan is to return a dictionary using the keyword "deletes". This keyword accepts 2 parameters: objectID / globalID. My question is: how could I use this keyword to delete multiple records without creating one "deletes" section in the dictionary for every record? Can I pass to "globalID" an array of globalIDs of the feature I want to delete from the related table?
Also, my parent feature have several records in the related table but I only need to delete some of those records, which I can filter using a field in the related table. If I use the function "FeatureSetByRelationshipName" I can get all the records associated with the parent feature as a FeatureSet, then filter the returned FeatureSet to leave only the features that I want to delete. The question then is how to pass all the filtered records to the return dictionary without doing it one at a time?
Regards.
