Get table name and short name of the table in the arcade expression when creating constraint
745
08-18-2023 05:51 AM
JohnP18
I am creating a constraint at the feature or row level. In that constraint one of the use case is to get the table name and short name of the table on which the constraint is being applied.
Any help??
@HusseinNasser2
Tags (1)
JohnP18
Any help?  If it is possible?  @HusseinNasser2
MikeMillerGIS
Esri Frequent Contributor
Since the rules are applied to a FeatureClass, why do you need this info.  Can you just hard code it?
JohnP18
@MikeMillerGIS right now I am doing that but just in case I wanted to check if it is possible.
