Hello -
I am new to writing attribute rules in Pro (but not new to the concept), and I am using 3.5.2. In designing a rule to run on an insert trigger, it would be helpful to know if that insert was triggered from pasting a feature versus creating a new feature. Is that information available to me in something like $editcontext? I know that the rule 'knows' that it is a paste or create (via error message - see below), but I do not how to access that information in the rule itself (if that is possible).
I spun up a simple attribute rule that just returns a couple of $field.<field name> values via of an error message to illustrate. When I attempt to create a feature, the error message shows that I was (attempting to) create a new feature:
When I attempt to paste a copied feature, the error message shows this:
Is it possible to suss out that distinction in the rule itself? If so, I would be able to follow a different logic path depending on what was happening.
Thanks so much.
