How to add the new OSTN02 NTV2 Transformation to ArcReader 10.0
4017
03-15-2011 11:50 AM
JimSibbald
Ordnance Survey working with Defence Geographic Centre have produced an NTV2 version of their OSTN02 transformation. Information about the transformation and the NTV2 file itself can be found at http://www.ordnancesurvey.co.uk/oswebsite/gps/osnetfreeservices/furtherinfo/ostn02_ntv2.html
The attached PDF shows how to add this to ArcGIS Desktop 10.0 but it is the same process for ArcReader. I have also included my GEOGTRAN file which needs the .txt extension removed to work. Enjoy!
JimSibbald
With the OSTN02 NTv2 Transformation being adopted by EPSG, I have changed the names of the transformations to reflect those of EPSG.  The CUSTOM transformation code must be in the range 208000 and so I have ensured that they reflect the EPSG code of 5338 and 5339 by using 208338 and 208339 respectively.
http://www.epsg-registry.org/report.htm?type=selection&entity=urn:ogc:def:coordinateOperation:EPSG::...
New GEOGTRAN file attached.
by Anonymous User
Not applicable
Original User: abdb2
Thanks for posting this - potentially very useful.  I put this into ArcGIS 9.3.1 and it seems to work fine but on transforming some sample points from BNG to WGS84 in Scotland using the OSGB_1936_To_WGS_1984_7 transform and the 'Project' tool they seem about 70m out from the lat/longs given by OS GridInQuest which is strange (as both should be using OSTN02).  The 'Petroleum' transform is about 5m out.
I realise you are not in a position to provide support but if any thoughts come immediately to mind on why this should be I'd be interested to hear.
Cheers
Duncan
