Hi all,
You are absolutely correct in saying that the reason the Navigation Toolbar has not dissapeared completely is due to the StreetMap Extension applet tools. If you want to create an ArcPad project that will launch only with your applet toolbars and none of the ArcPad defaults - why not use ArcPad App Shortcuts? You can configure the shortcut to reference applets from any folder, choose to ignore the default applet path and remove all of the ArcPad default toolbars. Even better, you can configure shortcuts on a per-project basis without having to alter your default ArcPad work environment.This functionality was added in ArcPad 10.0.2.
Hannah Ferrier
ArcPad Development Team
