Hello,
I am struggling with a projection issue in Arcpad 10.22. In ArcMap I created a shapefile layer of points by digitizing. I then opened arcpad and in a new map added the point layer rather than use ArcPad data Manager. View the two attached screen captures and you can see the huge discrepancy in the Lat/Longs from ArcMap to ArcPad in the Status Bar. Can’t figure why Arcpad shows 377,683+ degrees North when ArcMap correctly shows 86+ degrees South. Am using WGS 1984 Antarctic Polar Stereographic projection. Thanks in advance for any insights
John
The steps you describe sound correct (creating in ArcMap, add to a new map in ArcPad, they should appear the same), so i wonder if the projection that your expecting is in fact being used in ArcPad. To check:
1. Select the layer in the Table of Contents
2. Choose Map Properties
3. Go to the projection tab
Do you see the expected projection listed in the Projection page?
Signed in members can post, follow updates, and more. New here? Register a free account.
