Shape file with Z and M,
11029
9
01-10-2014 08:58 AM
JamalNUMAN
Legendary Contributor
I couldn???t figure out the distinction between having point shape file, pointZ and PointM.
[ATTACH=CONFIG]30395[/ATTACH]
What is the impact of these shape files as points are captured from the field?
Thank you
Best
Jamal
Jamal Numan
Tags (3)
LucasBannan2
Hi Jamal,
A quick answer to your question is that Z-Values (PointZ) have the ability to store elevation (such as GPS height) along with the default X,Y coordinates whereas M-Values allow the ability to store linear measurements (such as offsets within ArcPad). A few links below discuss these options a bit more in depth.
Working with offsets
GPS Height
Feature class basics (under the 'Vertical measurements using z-values' and 'Linear measurements using m-values' sections)
Hope this helps.
JamalNUMAN
Hi Jamal,
GPS Height
Hope this helps.
Many thanks Luke for the help.
I aimed at creating a shape file that stores XY and Z as points are captured from the ground. This is why I selected the pointZ.
[ATTACH=CONFIG]30399[/ATTACH], [ATTACH=CONFIG]30400[/ATTACH], [ATTACH=CONFIG]30401[/ATTACH]
At the end, I tried to open the pointz shape file from the ArcMap but it appears no field that stores the elevation values.
[ATTACH=CONFIG]30402[/ATTACH]
What might be the issue here?
Jamal Numan
JamalNUMAN
Enabling the z-value as a shape file is created
  • allows collecting the Z (elevation) when adding a shape file in an application (like ArcPad) installed in GPS device,
  • allows adding the Z value through the “edit sketch properties” in the ArcMap
Jamal Numan
JuanLuera
Hola Jamal,
I wanted to add my two cents to your post, and hopefully this applet will assist you and make things easier for you. Since I see you are looking to capture Z & M values for your data, here is a ArcScript that may make things easier for you in your workflow. This is not written by Esri or supported by us (Support Services/Esri) but we do post items that may assist our customers.
Good Luck!
Gracias, Jamal!
Add XYZ to Table
http://arcscripts.esri.com/details.asp?dbid=16785
Juan
JamalNUMAN
Thanks Juan,
My issue here is how to stick the Z-value in the attribute table in case the Z-value is set to be enabled. The XY coordinates can be calculated using the “add xy coordinates” tool but how about the z value? How it can be incorporated in the attribute table as a field?
Jamal Numan
JamalNUMAN
It works fine
Jamal Numan
DanPatterson_Retired
Yes, that is what it said...but only for ZM enabled files
JamalNUMAN
Thanks Dan.
Jamal Numan
