Query feature causes error in ArcPad 8.0
1522
06-04-2010 07:56 AM
YukunXing
Again, new user of ArcPad user, so any help is appreciated.
I've used the feature query a few times and it's working fine. However, on this particular dataset, I got this "Null result rowset" error, see attached image.
I suspected it's data related, however the same query would work in ArcMap. I tried checking out the data several times, but once in ArcPad, the query on the same text field won't work.
And thought on what could be the potential cause of this?
I shall add that if the same data is checked out as a shapefile, the same query works fine in ArcPad. The error occurs when data is checked out as AXF file, which is the format I need.
Tags (3)
