Installing ArcPad 10 on Trimble Juno 3D  ## not working ##
6231
10-30-2012 01:15 AM
PeterHintze
how can i install ArcPad on the Trimble Juno 3D?
Thank you!
Peter
Tags (3)
HannahFerrier
Hi Peter,
After you have installed ArcPad 10 on your Windows Desktop PC, turn on your Juno 3D and connect it to your PC using a USB cable and the Windows Mobile Device Manager Software.
Once your Juno 3D is synched up to your PC, open the ArcPad Deployment Manager on your desktop PC (look in the ArcGIS/ArcPad folder in your Start Menu). Check the box labelled 'Install ArcPad for Windows Mobile' and click 'Deploy'.
Now, if you look at your Juno 3D, you should see ArcPad installing!!
Use the same license code that you used to register ArcPad on your PC to register ArcPad on the device (each license code is good for one desktop and one mobile version of ArcPad).
Let me know how you get on!
Hannah
[ATTACH=CONFIG]18865[/ATTACH]
Carey-LeeDixon
Thanks Hannah, this was a quick refresher.
