Checked-out file won't open on my Trimble GeoXH unit
663
04-06-2010 04:31 AM
innocent_marvintetteh
I'm having problems opening checked-out data on my mobile device, the CAB file gets deployed successfully to the mobile unit but stops responding when I try to open the apm or the axf file. I'm not sure if it is the file size, about 9.5MB. Slower to open on desktop and sometimes some features will not show up.
The AXF files are checked out from a personal geodatabase with all relationships.
Can anybody let me know what I could be doing wrong?
Marvin
Tags (3)
KyleCollins
Marvin, I'm setting up a GeoXT with ArcPad 8 and I'm having the same issue.
My exported CAB file is only 1.7MB, so size is probably not your problem.
I have put in a request at ESRI Support webform twice and both times the website blows up and sends be back to the beginning.   Very frustrating...
So far, 8 isn't working for me.
If you get a fix, please let us know.
Thank you,
Kyle
KyleCollins
I just noticed this in the READ ME file.
"Note: Pocket PC, CE .NET and Windows 2000 are not supported platforms for ArcPad 8.0 SP2
On Windows Mobile, ArcPad 8.0 SP2 supports the ARM - based CPU chips.
These include CPU chips from the following manufacturers:
         · *Intel (StrongARM, XScale)    (Trimble Geo's)
         ·   Samsung
         ·   Texas Instruments (OMAP)
When using Microsoft XP, Microsoft ActiveSync 4.2 or higher is required. When using Microsoft Vista, Windows Mobile Device Centre 6.1 or higher is required.
The ArcPad Data Manager Extension for ArcGIS  ®   Desktop requires ArcView ®  , ArcEditor�?�, or ArcInfo ®   9.3   or higher.
The ArcPad ArcGIS® Server Extension requires ArcGIS ® Server Advanced Enterprise Edition 9.3 or higher."
We are still using 9.2.
I don't know if this may be causing some indigestion..
