Can't get ArcPad form to open with SIP opened.
2806
07-16-2011 07:30 AM
PatrickMurphy
I can't get a form to open with the SIP keyboard already open.  I have been using ArcPad Studio, and I set the sip = true for the Form, for the Page, and for the Control.  I have also set them false for the Form and Page and control in different combinations thinking that somehow it is getting toggled on/off at each level.
Any ideas how to get a form to open with the keyboard SIP already open?
Tags (3)
JuanLuera
At the moment our developer's are aware of this issue with forms within a SIP keyboard is open.
I am including a few logged bug's with developement.
Unfortunately, this is the behavior of the SIP on smaller handheld mobile devices because of limited screen real estate.
CQ00310810; Automatically add scroll bars to custom forms on a mobile device.
CQ00117762; AutoHScroll in Forums input fields.
NeilChristie
If the result you want is to have the SIP displayed as soon as the form opens then you can use the SetFocus method on a form edit control as part of the form's initialisation. This will show the SIP when the form opens.
Cheers,
Neil.
PatrickMurphy
Thanks for the response, but can you give more details on how this is done using ArcPad Studio.  I tried adding an attribute called setfocus = The target control with the sip=true, but that didn't work since there is no setfocus attribute.  What exactly is it that you are describing?
Perhaps I am getting closer.  I can open up the form layout screen by double clicking the <EDIT FORM> line.  Then I can double click on the first control that the cursor occurs in <EDIT> Comment,  and get the properties window.  I can then go to Events and then enter OnSetFocus.  Then I need to enter VBscript that will open the SIP and I have no idea what that code should be.
PatrickMurphy
After trying for a long time to figue this out, since no one provided any useful help, I figured out that you have to turn off the Tab Stop check box in the control properties in ArcPad Studio.  I guess that when the control is the first item on the tab list, and the cursor is already in the control, it somehow bypasses both the sip = true in the on got focus event as well as the default sip check box in the cotrol properties.
