We tried using the cameras on the Yuma, and found out the quality plus the viewing of images was not good at all. We began using Eye Fi cards and it made things a lot easier. If you want to stick to the way you are doing it...I believe you can go inside arc pad into advanced options and change the setttings to not use the Arc Pad viewer (Just uncheck it) and rather use the Windows Viewer.
So just to clarify. Does this mean that there is no solution to this? Or does that mean that if you call support they can help work around it? Thanks
Did you ever find a solution to this?
Just wanted to chime in and say that still is not resolved. Brand new Yuma 2 (Win7) with ArcPad 10.2 R2 (Build 50) can only take pictures from inside ArcPad at 640x480. Camera works fine up to the advertised 5MP outside of ArcPad though. I opened a case, and Esri support was able to repeat the behavior. It has as since been attached to this bug (NIM089150) and closed out. I'm seeing that this bug is now 2.5 years old with a severity of High. Crossing my fingers, but won't hold my breath.
