ArcPad 10 &  Business Analyst
2049
08-01-2012 05:29 AM
EdSchools
Maybe I'm doing something wrong here but I can't find it. I had an ArcMap 10 project set up to check data in and out to ArcPad 10. Worked fine on multiple occasions. Now the buttons on the ArcPad Data Manager tool bar are grayed out. I have tried creating a new project and the same thing happens. Since setting up the project I have installed Business Analyst. Are these related? Anyone know of conflicts between Business Analyst and ArcPad Data Manager? AM I just missing something really simple?
Ed Schools
MSU - Natural Features Inventory
Tags (3)
JuanLuera
Hola Ed,
I would say these two products are not related, unless you upgraded your ArcMap since installing Business Analyst. If this was done, then the order of installation was broken, and you will need to simply uninstall/re-install ArcPad. It also sounds like you may have somehow deactivated the extension within ArcMap, so all you would need to do within ArcMap�??s Customize>Extensions activate your ArcPad Data Manager. This should allow you to now check data out and back in from ArcPad, from within ArcMap. If you still see this issue and you are current with your maintenance, please log a Support webform and I would be glad to work with you on this issue. Gracias, Ed!
Support Service
1-888-377-4575
http://support.esri.com/en/webform/s...275/chat/false
EdSchools
Juan,
I hate being outwitted by inanimate objects. You are correct; the ArcPad Data Manager extension was turned off. No idea how it was turned off and it was the only extension that was turned off. If I find the gremlin responsible he (or she) will be dealt with appropriately.
ed
JuanLuera
Gracias Ed!
I greatly appreciate the update and have a great week!
