ArcPad 10.1 stops working when opening a specific .apm. What is causing this issue?
814
6
02-25-2018 04:03 PM
AnnaAnderson2
When I go to a .apm I am using I say- "open last map used" then ArcPad shows an error window- "ArcPad has stopped working" and closes the application. If I navigate to the .apm using "choose map to open"- the same thing happens. I can open other apms successfully. What is causing this issue?
DanPatterson_Retired
was everything in the same location as the last time it was successfully opened?
AnnaAnderson2
Yes
Something is corrupted then, so barring any further information, it is hard to pinpoint a source of the error or a solution
StephenQuan1
Hi Anna,
Sounds like some troubleshooting is required.
Here's two techniques.
1) Chopping technique
Make a backup of the APM, then, start chopping XML tags away from it in a step-by-step fashion until you end up with a barebones APM. At one point it should open, then, you should narrow down the "last thing" that caused it to change from crashing to not crashing.
2) Additive technique
Create a blank new APM, then, start adding XML tags from the APM that doesn't work in a step-by-step fashion, until you end up with the original APM. At one point, the APM should stop opening, then, you should narrow down the "last thing" that caused it to change from not crashing to crashing.
Once you've isolated the line, this would provide us with further information as to what is going on.
Stephen
AnnaAnderson2
Stephen,
Thank you for the suggestion I have been working on this issue this evening.
I determined one layer associated with that apm will crash ArcPad in a new map.
How do I repair that layer?
JavierBetancourt
I had a similar error, it turned out that the APM I wanted to use was too heavy for the device's memory or ArcPad. The solution had to be divided into several APMs and so I work.
Saludos
Javier
De: Anna Anderson<mailto:geonet@esri.com>
Enviado: domingo, febrero 25, 2018 7:08 PM
Para: Javier Betancourt<mailto:Javier.Betancourt@geoint.ec>
Asunto: - ArcPad 10.1 stops working when opening a specific .apm. What is causing this issue?
GeoNet <https://community.esri.com/?et=watches.email.thread>
created by Anna Anderson<https://community.esri.com/people/monturecreek?et=watches.email.thread> in ArcPad - View the full discussion<https://community.esri.com/message/752945-arcpad-101-stops-working-when-opening-a-specific-apm-what-is-causing-this-issue?et=watches.email.thread>
Reply to this message by replying to this email, or go to the message on GeoNet<https://community.esri.com/message/752945-arcpad-101-stops-working-when-opening-a-specific-apm-what-is-causing-this-issue?et=watches.email.thread>
Start a new discussion in ArcPad by email<mailto:discussions-community-gis-applications-arcpad@mail.geonet.esri.com> or at GeoNet<https://community.esri.com/choose-container.jspa?contentType=1&containerType=14&container=2126&et=watches.email.thread>
Following ArcPad<https://community.esri.com/community/gis/applications/arcpad?et=watches.email.thread> in these streams: Inbox
This email was sent by GeoNet because you are a registered user.
You may unsubscribe<https://community.esri.com/unsubscribe.jspa?email=javier.betancourt%40geoint.ec&token=3276105fc6af9ff84e257e44b5b5542a895dab7823f376c8f3cd7a5f77fb367c> instantly from GeoNet, or adjust email frequency in your email preferences<https://community.esri.com/user-preferences!input.jspa>
