With Desktop 10.1, is there a way to change the JVM runtime?
821
07-24-2013 05:33 AM
ChrisGreen
Prior to ArcGIS Desktop 10, the Java Configuration Tool allowed one to specify an alternate JVM (http://resources.esri.com/help/9.3/arcgisserver/adf/java/help/doc/5ea8aa1a-0b3e-46c1-8589-757bdc50d4...).  In 10.1 that is no longer an option, as far as I can tell.  I noticed that between 10.0 and 10.1 the JRE rolled back one update.  I'm noticing some issues w/ a Java add-in I created that works fine in 10.0, and I would like to rule out the JVM change.  Can I change the default JVM setting?  Thanks in advance, cg.
ChrisGreen
To follow up, I found out from ESRI that the answer to this question is 'No'.  You can't alter the JVM used by ArcGIS to run Add-Ins.
