Warning in Starting Editing: No Editable Layers
958
07-05-2017 11:48 AM
ShaningYu
Honored Contributor
I posted a thread about 10 days ago at
Not successful in updating myVersion  in which I present a problem Not successful in updating myVersion using ArcObjects (as a feature is Inserted into myVersion, this feature is also inserted in other versions too).  Then, I tested a editing on ArcMap.  A SDE versioned layer is loaded on ArcMap session.  However, when I Start Editing, I got warning: No Editable Layers.
I searched around for "No editable layers" but could not find the proper solution.  I appreciate if you can share your experience.
Tags (1)
