Utility objects java
690
10-14-2011 03:23 PM
ErikEklund
I have discovered a strange thing with the Utility Object function with java and ArcDesktop.
I deploy an Addin to be the jar file with everything. Then I deploy a jar file with the Utility Objects.
This is necessary because it makes things go faster.
The strange thing is that the First time You use ArcMap it will use the newly jared classes. Next time it will use what is in your esriaddin-jar file.
Whats up with that?
There seems to be two jar-files containing the same classes.
Comments, please...
