Table of Contents 9.3 vs 9.4
3020
10
10-27-2009 09:48 AM
by Anonymous User
Not applicable
Original User: maplogic
I am trying to find more information about how the ArcMap Table of Contents (IContentsView) has changed in 9.4 compared to older versions.
Specifically, can developers still add custom tabs in the Table of Contents?  If so, how is this done?  Code that worked to add a custom tab in older versions no longer seems to work.
I've also noticed that a Table of Contents Tab no longer exists in the ArcMap options dialog.
I would appreciate any insider information about this.  Does ESRI want developers to use IDockableWindow instead?
by Anonymous User
Not applicable
Original User: gottralf
There is no other place in ArcMap where you can change the font size for your TOC.
Do you or people in your organization use this option often?  I can log an enhancment for you to request to bring this functionality back.  It would be helpful to tell me why and how you use this.
Thanks.
