Hi, I have featureclass and a table who's data i wish to join. I am using the AddJoin class to perform this operation. However after the join i get a layer like "GPL0" in the TOC with the results. Why hasn't the join got applied to the featureclass? If I run the AddJoin tool manualy from the toolbox in ArcMap the result appears in the featureclass table. But the same does not display when I try to achieve it programatically. Is it possible to rename or export GPL0?
Here is my snippet.
ITable pDerivedTable = OuputFGBLocation.OpenTable(tablename);
//ITableView pJoinTableView = new TableViewClass();
//pJoinTableView.Table = pDerivedTable;
//GDM Layer
ITable pGDMFClassTable = pGDMFclass as ITable;
//ITableView pGDMTableView = new TableViewClass();
//pGDMTableView.Table = pGDMFClassTable;
AddJoin pAddJoin = new AddJoin();
pAddJoin.in_layer_or_view = pGDMFClassTable;
pAddJoin.in_field = pGDMFClassTable.Fields.get_Field(pGDMFClassTable.Fields.FindField(AddInObjects.GDMID_FIELD_NAME));
pAddJoin.join_table = pDerivedTable;
pAddJoin.join_field = pDerivedTable.Fields.get_Field(pDerivedTable.Fields.FindField("ORIGGDMID"));
pAddJoin.join_type = "KEEP_COMMON";
pGp.Execute(pAddJoin,null);
Regards,
Nigel.
