Not able to work with Arcmap with Customized command
1302
01-16-2014 10:39 AM
SaurabhGupta1
I have created one customized command and by clicking on that one window form is open, but when winform is enable not able to work on ArcMap, I want to work on Arcmap too with customized form. can anyone please suggest how to do that?
NeilClemmons
Honored Contributor
Sounds like you're opening a modal form when you want to be opening an modeless form.  In .NET, you call Show() instead of ShowDialog() to do that.
NeilClemmons
Honored Contributor
SaurabhGupta1
Yeah..I found the same solution. Any Way Thanks for your Help.
