.NET SDK - Newbie runtime dependency error
4570
08-18-2011 03:51 AM
TomWilcox
I am a complete newbie to ArcGIS SDK and I have encountered the following error when compiling and running a .NET Sample:
System.BadImageFormatException was unhandled
  Message="Could not load file or assembly 'ESRI.ArcGIS.System, Version=10.0.0.0, Culture=neutral, PublicKeyToken=8fc3cc631e44ad86' or one of its dependencies. An attempt was made to load a program with an incorrect format."
  Source="RasterSyncExtensionReg"
  FileName="ESRI.ArcGIS.System, Version=10.0.0.0, Culture=neutral, PublicKeyToken=8fc3cc631e44ad86"
  FusionLog="=== Pre-bind state information ===\r\nLOG: User = CSE\\tomw\r\nLOG: DisplayName = ESRI.ArcGIS.System, Version=10.0.0.0, Culture=neutral, PublicKeyToken=8fc3cc631e44ad86\n (Fully-specified)\r\nLOG: Appbase = file:///C:/Program Files (x86)/ArcGIS/DeveloperKit10.0/Samples/ArcObjectsNet/RasterSyncWorkspaceExtension/CSharp/RasterSyncExtensionReg/bin/Debug/\r\nLOG: Initial PrivatePath = NULL\r\nCalling assembly : RasterSyncExtensionReg, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null.\r\n===\r\nLOG: This bind starts in default load context.\r\nLOG: No application configuration file found.\r\nLOG: Using machine configuration file from C:\\Windows\\Microsoft.NET\\Framework64\\v2.0.50727\\config\\machine.config.\r\nLOG: Post-policy reference: ESRI.ArcGIS.System, Version=10.0.0.0, Culture=neutral, PublicKeyToken=8fc3cc631e44ad86\r\nLOG: Attempting download of new URL file:///C:/Program Files (x86)/ArcGIS/DeveloperKit10.0/Samples/ArcObjectsNet/RasterSyncWorkspaceExtension/CSharp/RasterSyncExtensionReg/bin/Debug/ESRI.ArcGIS.System.DLL.\r\nERR: Failed to complete setup of assembly (hr = 0x8007000b). Probing terminated.\r\n"
  StackTrace:
       at RasterSyncExtensionReg.RegisterExtension.Main(String[] args)
       at System.AppDomain._nExecuteAssembly(Assembly assembly, String[] args)
       at Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly()
       at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
       at System.Threading.ThreadHelper.ThreadStart()
  InnerException:
The paths to the referenced ArcObjects are correct...
Any help would be much appreciated.
Cheers,
Tom
SumitSharma
Hello Tom,
What kind of license do you have i.e. ArcInfo or ArcGIS engine ?
Also, Can you provide details on machine specification like is it 32 bit or 64 bit etc.
Cheers!!
Sumit
TomWilcox
Hi Sumit,
Thanks for the response.
The license type (via ArcMap->About) is ArcInfo.
The machine is running 64-bit Windows Server 2008 R2.
Tom
ToddHay
I'm curious if you ever resolved this error as I'm running into the same problem.  My environment is ArcInfo 10 sp2 on Windows 7 64-bit.  I'm using Visual Studio 2008 Express for C#, however I recently loaded the ArcOjbects .Net SDK 10 sp2.
Thanks.
Todd
ToddHay
I was able to answer my own question.  I had to change my target configuration to be x86 (32-bit) versus x64 (64-bit).  I did this as follows:
  • Tools -> Options -> Projects and Solutions -> General
  •     Check Show advanced build configurations
  • This then showed the Solution Platforms combobox
  • Select Configuration Manager... from this combobox
  • In the "Type or select the new platform," type "x86"
  • Hit OK
That should do the trick.
