Is it possible to use the arcpy.mapping classes within visual studio?
5947
15
05-24-2016 09:26 AM
maxsteinbrenner
So is there a way you can use arcpy code from within a vb.net project? Currently have a pretty big custom set of addin's written in vb.net and can't figure out how to do one part of what i want with .net code. In acpy it is easy so i was wondering if i could somehow stick a little arcpy code in the visual studio project?
maxsteinbrenner
Duncan,
Thanks SO MUCH
Here is the working result:
    Private Sub Export_to_shp()
        Dim GP As IGeoProcessor = New ESRI.ArcGIS.Geoprocessing.GeoProcessor
        With GP
            .OverwriteOutput = True
            .LogHistory = False
            .AddOutputsToMap = False
            .TemporaryMapLayers = True
        End With
        Dim m_pMxDoc As ESRI.ArcGIS.ArcMapUI.IMxDocument
        m_pMxDoc = My.ArcMap.Document
        Dim in_features As String = m_pMxDoc.FocusMap.Layer(2).Name
        Dim pVA As ESRI.ArcGIS.esriSystem.IVariantArray = New ESRI.ArcGIS.esriSystem.VarArray
        With pVA
            .Add(in_features)
            .Add("H:\SwiftReach")
        End With
        GP.Execute("FeatureClassToShapefile", pVA, Nothing)
    End Sub
If you see anything that could still use some fixing let me know. I am no programmer, but I try my best...
DuncanHornby
MVP Notable Contributor
Glad you got it working! I would pass the result of the call to the tool into a pGeoProcessorResult object, you can then test the status, did your code succeed or fail, you can also retrieve from this object the error message which may give some indication to why it failed. It's just better coding to be defensive.
maxsteinbrenner
i was wondering how to do that!
better?
thx max
KenBuja
MVP Esteemed Contributor
I've always went the route of using the managed assemblies when using the Geoprocessor in .NET. Here's an example of how I run the Dissolve tool, using inputs representing either feature classes or feature layers (either as path names or as ArcObjects) and all the associated functions to execute the Geoprocessor and return a feature class.
Dim GP As ESRI.ArcGIS.Geoprocessor.Geoprocessor  'set in the beginning of the code
Friend Function DissolveDataset(ByVal InputName As Object, ByVal DissolveField As String, ByVal StatsFields As String, ByVal OutputName As String) As ESRI.ArcGIS.Geodatabase.IFeatureClass
    Dim DissolveDS As New ESRI.ArcGIS.DataManagementTools.Dissolve
    Dim Result As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2
    Try
        Using releaser As New ESRI.ArcGIS.ADF.ComReleaser
            releaser.ManageLifetime(DissolveDS)
            DissolveDS.in_features = InputName
            DissolveDS.dissolve_field = DissolveField
            DissolveDS.statistics_fields = StatsFields
            DissolveDS.out_feature_class = OutputName
            Result = RunTool(DissolveDS, Nothing)
            If Result Is Nothing Then
                System.Windows.Forms.MessageBox.Show("Could not dissolve dataset")
                Return Nothing
            End If
            Return ReturnObjectfromResult(Result, "Feature Class")
        End Using
    Catch ex As Exception
        System.Windows.Forms.MessageBox.Show(ex.ToString, "Dissolve error")
        Return Nothing
    End Try
End Function
Friend Function RunTool(ByVal Process As ESRI.ArcGIS.Geoprocessor.IGPProcess, ByVal TC As ESRI.ArcGIS.esriSystem.ITrackCancel2) As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2
    Try
        Result = CType(GP.Execute(Process, Nothing), ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2)
        If Result.Status <> ESRI.ArcGIS.esriSystem.esriJobStatus.esriJobSucceeded Then ReturnMessages(Result, "Geoprocessing Error")
        GP.ClearMessages()
        ReturnMessages(Result, "Fail")
        System.Windows.Forms.MessageBox.Show(ex.ToString, "Run Geoprocessor")
    End Try
    Return Result
End Function
Private Sub ReturnMessages(ByVal pResult As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2, ByVal Title As String)
    Dim ErrorMessage As String
    If pResult.MessageCount > 0 Then
        For Count As Integer = 0 To pResult.MessageCount - 1
            ErrorMessage += pResult.GetMessage(Count)
    End If
    System.Windows.Forms.MessageBox.Show(ErrorMessage, Title)
End Sub
Friend Function ReturnObjectfromResult(ByVal result As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2, ByVal Type As String) As Object
    Dim GPVal As ESRI.ArcGIS.Geodatabase.IGPValue
    Dim InMemFC As String
    Dim GPUtil As ESRI.ArcGIS.Geoprocessing.IGPUtilities3 = New ESRI.ArcGIS.Geoprocessing.GPUtilities
    Try
        GPVal = result.GetOutput(0)
        InMemFC = GPVal.GetAsText()
        Select Case Type
            Case "Feature Class"
                Return GPUtil.OpenFeatureClassFromString(InMemFC)
            Case "Table"
                Return GPUtil.OpenTableFromString(InMemFC)
        End Select
        System.Windows.Forms.MessageBox.Show(ex.ToString, "Return FeatureClass error")
        Return Nothing
    End Try
End Function
DuncanHornby
Hi Ken Buja​,
I've always wondered if there was an advantage in using managed assemblies (the way you have shown) compared to the way I have done it? I've continued to use the method I use to call geo-processing tools simply because it was the method I first learnt and I can remember how to do it!
Duncan
KenBuja
I don't know if there are computational advantages of using the managed assemblies. I've gravitated to them because you know exactly which parameter is getting set (and in no particular order) as opposed to having to remember their correct order when adding them to the IVariantArray
