How to uncheck the option "Show Getting Started Dialog"?
1867
03-18-2014 06:52 AM
SanajyJadhav
I want to uncheck the "Show Getting Started Dialog" chekcbox ( screen shot is attached here ).So that Getting Started Dialog box does not appear when the ArcMap starts.
For this my guess is, I have to use IStartupDialogSettings interface.If this is the case, I am not getting how to use this interface.So, any help is appreciated on this.
Thanks in advance.
S.
by Anonymous User
Not applicable
The checkbox sets the following registry key:
HKEY_CURRENT_USER\Software\ESRI\Desktop10.2\ArcMap\Settings\GettingStarted\ShowStartup
Your easiest option is to manipulate that value.
by Anonymous User
Not applicable
SanajyJadhav
Thanks Sean,
It worked. Appreciate your help.
Below is my code.
                string keyPath = @"Software\ESRI\Desktop10.2\ArcMap\Settings\GettingStarted";
                keyForGettingStartedDialog = Registry.CurrentUser.OpenSubKey(keyPath, true);
                keyForGettingStartedDialog.SetValue("ShowStartup", "0");
S.
