How to save MXD from ArcGIS 10 to ArcGIS 9.3
1271
12-06-2011 07:30 AM
FabriceCEBRON
I have more than 200 mxd document which were created and saved into the ArcGIS 10 version.
However, I have to save them into the ArcGIS 9.3 version 😞
I know the command "Save A Copy" from the File Menu of ArcMap, but i would to do this automatically.
But in ArcObject I don't find this fonction. The IMapDocument.SaveAs function or then IApplication.SaveAsDocument fonction seem to save only in the current version....
Thanks for your help
Regards....
NeilClemmons
Honored Contributor
I believe you QI from IMapDocument to IDocumentVersion and set the DocumentVersion property before saving.
FabriceCEBRON
Thanks for your answer, it works...
