How to release a raster file from locking after deleting it's layer from arcmap using arcobjects
1669
10-06-2016 09:50 AM
ShehabAhmed2
I'm creating an addin in which I need to delete the raster file after deleting it's layer from the current map.
The layer is deleted no problem.
ArcMap.Document.FocusMap.DeleteLayer(layerToRemove);
ArcMap.Document.UpdateContents();
ArcMap.Document.ActiveView.Refresh();
Marshal.FinalReleaseComObject(layerToRemove);
The issue is this: when I try to delete the source file, it gives me IO exception that is the file is in use with arcmap process.
Any help will be appreciated.
ShehabAhmed2
Actually after asking a friend , the perfect working solution is to use the Arcmap delete tool
ShehabAhmed2
