How to get all segments of all polygons in a polygon feature class - how  do it fast
1523
05-20-2010 07:14 AM
VladiH_
this is my first post - I am pretty new to Esri & gisses.
I am using FileGeoDatabase and C#
What is my problem: The SPEED of getting all segments of all polygons in a feature class. I found out about two ways how to do it:
First way:
   1. enumerate all polygons, get every single one's ExteriorRingBags (inputPoly.ExteriorRingBag),
        2. enumerate all it's exterior rings, get segments from every exterior ring and get interior ringbag of every  exterior ring (inputPoly.get_InteriorRingBag(extRing))
            3. enumerate all interior rings of every interior ringbag and get it's segments
    This way I can collect all segments from all features of a polygon feature class and use them somewhere else (I actually just need the start and end coordinates of each segment)
Second way:
     Usings the function: "FeatureToLine" I can store all features of a polygon feature class, but then I need to get every single segment of the newly created Line class.
The "First" way => to go through all the ArcObjects, through all the enumerations to collect the semgents, is damn slow and therefore not usable - to collect all segments (finally I got them 218 000) of 17000 features lasts over 30 minutes
The "Second" way is a bit faster, because there are not as many enumerations as in the first way, but it is still slow...
Therefore my question: Does anybody know how to query/get all segments of all polygons really fast way? I really need to get through them within seconds or worst - within "very" few minutes, but can't let the algorithm work for 30 min....
Does anybody know how to help me?
Every help is appreciated!!!
Thanx,
   Vladimir
KirkKuykendall
Have you tried IGeometryBridge.QuerySegments ?
One of the design goals of IGeometryBridge is to improve performance.
http://resources.esri.com/help/9.3/arcgisengine/dotnet/b0e79fb3-ee12-4cbc-a31f-60f1eb4a4861.htm
VladiH_
Hi kirkktx!
      Thank you for your answer and new ideas - ok, I tried IGeometryBridge.QuerySegments, but it still does not improve performance signifficantly - with this amount of features it saves some 5 minutes, so the whole iterating lasts 25 minutes instead of 30 minutes. The problem stays that I still need to iterate through: all polygons, their external and internal rings, cast each ring to ISegmentCollection and first this I can use with IGeometryBridge.QuerySegments... :-(.
But the link you provided shows that using Visual C++ on problem parts instead of using C#, can save some signifficant time - they show how using C# 2.0 costs 6 times more time time than using Visual C++!!!. I am using C# 3.5, which has got improvements in speed against C# 2.0. It looks like I have to rewrite the problem parts into C++ & then we will see if the speed improves enough...
But there is one thing bothering me - as we are using C# in our development environment, I will need a C# solution... and... I cannot believe ESRI is letting you rewrite your code into C++ to solve performance problems... Is there not some another "C#" solution?
Thanx for your help, -still, any help is appreciated!!!
KirkKuykendall
Have you considered using ArcSDE?
Maybe try SqlServer with  SDEBINARY option.
VladiH_
Thx, but I need it with File Geodatabase and may be other types of databases too... I probably have the solution... -Now no matter which type of database I choose, it always remains fast. What I did: I at last rewrote it into unmanaged C++ as Esri proposed it in the link you provided. Now the running of the whole  code (the one that lasts for around 25-30 minutes in C#) lasts for no more than 20 SECONDS!!!  ...But the sad problem remains that in C# ( I am using 3.5) there is probably no other solution...?? I will try other SQL solutions including ArcSde once I will have an SQL server, but now I am searching for kind of general solution which will work everywhere.
