Is there a way to access the ArcMap Options using ArcObjects (In ArcMap select Customize - ArcMap Options)?
try see IRasterDefaultsEnv9 Interface (ArcObjects .NET 10.1 SDK) IRasterDefaultsEnv1..9
I need to change the raster layer settings. However, I cannot find IRasterLayerSettings or similar.
for example for cad:
//Set CadSettings to a new CadWorkspaceFactory. ESRI.ArcGIS.DataSourcesFile.ICadSettings pCadSettings = new ESRI.ArcGIS.DataSourcesFile.CadWorkspaceFactory()as ESRI.ArcGIS.DataSourcesFile.ICadSettings; //Enable support to examine all files for DGN format. pCadSettings.EnableAllDgnFileExtensions = true; //Print the results to the console. Console.WriteLine("EnableAllDgnFileExtensions = {0}", pCadSettings.EnableAllDgnFileExtensions);
or for example hardware acceleration (IGlobalScreenDisplaySettings ) :
ArcObjects Help for .NET developers
see Interface *Settings
What's the setting that you need change?
