Help ! How to programe the object of armap by using c# ?
586
04-13-2013 08:25 AM
Do_NgocNam
Hi everyone !
Details follow :
mba110_22 layer has the Enabled field. This Enabled field includes 2 values which are True(pink color) and False(Red color).
The first,This Enabled field is True value(pink). When i click on the object on the map, this object will transform into False value and Timer(in c#) counts the number of times. The, i click on the object on the map again, this object will transform into True value and Timer stop counting. This number of times will being saved in access database.
Thanks and regards !
