Failed to open raster dataset error
4253
05-17-2012 08:30 AM
CarlosPiccirillo
Hi everyone,
The code below has been functioning fine for years in VBA and now C# but suddenly stopped working this week. I can load raster imagery manually but the code below fails on the last line and I get a "failed to open raster dataset" error.
Anyone have an idea what I can do to fix this?
Carlos
IWorkspaceFactory pWorkspaceFactory = new RasterWorkspaceFactory();
IRasterWorkspace pRasterWorkspace = pWorkspaceFactory.OpenFromFile(rasterPath, 0) as IRasterWorkspace;
IRasterDataset pRasterDataset = pRasterWorkspace.OpenRasterDataset(rasterName);
alexandrudragomir
I have the same problem when I'm trying to access a raster dataset from a geodatabase.
CarlosPiccirillo
I am facing a similar problem while accessing a raster from a geoDB. Did you find a solution?
No, I didn't.
AhmedEl-Sisi
It's mentioned here that To access raster from geodatabase, use IRasterWorkspaceEx interface.
Regards,
