Data frame propertis is not working after converting BLOB to map
3851
09-28-2014 09:58 PM
SreerajanParamanandham1
Dear Friends,
I am trying to convert the BLOB to Map(Layers) using the attached code, the conversion is working properly but i am facing the following issues
1.) Data frame properties are not working when double click the map(Layers) or Toolbar->View->Data Framme Properties,
2.) Right click "Remove" is not working.
3.) Save as MXD , close and reopen the same mxd,  the layers and data source contents are not visible, when i am reading the same through the code layers and source are available
Attachment contains the upload and download tools
Upload-> convert maps(layers) to blob
download-> convert blob to maps(layers)
Thanks and regards
Sreerajan P
sreerajan.paramanandham@cyient.com
Tags (4)
