create polygon from polygons and polylines
1158
11-11-2012 12:15 PM
InsuHong1
I want to create polygon from polygon and polyline.
Just like this. I want to create polygon which is filled gap between polygon and polyline.
[ATTACH=CONFIG]19208[/ATTACH]
In ArcMap, I used 'feature to polygon' tool for that. But it did not work properly in C# Add-in.
I repeat that operation with several hundred lines and same polygon. The very first operation works well. But in the second iteration, "feature to polygon" tool just make error. I set on 'overwright' for geoprocessing. And I erase prior result before start next iteration. erasing operation goes well.
Is there any other way do same job? Actually, 'feature to polygon' tool spends 1 sec for operation. But I have to repeat same operation for hundreds of thousand lines, I need faster way to do it.
Or anyone has idea what's the problem?
