Classified Renderer -- "flip" color ramp options?
781
01-15-2013 05:49 AM
JamesCrandall
I am implementing IRasterClassifyColorRampRenderer using an EqualInterval class breaks and manually setting min/max and number of classes for each raster loaded in an ArcScene document.  All works exactly as expected but I have a request to "flip" the color ramp and I cannot seem to find how to get this done.
Manually, I would just access the symbology via properties menu, select all of the classes/symbols, right-click and choose "flip colors".
Of note: I am not manipulating the IColorRamp at all, rather I am enumerating thru the StyleGallery and selecting one by name (eg. "Blue-Dark to Cyan-Light").
So, with all this said...  Can I simply issue a .FlipColorRamp somehow???  🙂
Prefer VisualBasic but can probably figure out the C# if you have an example.
James
DuncanHornby
MVP Notable Contributor
James,
Search for IRasterStretch2 Interface it has an invert method, not used it but my money is on that!
Duncan
JamesCrandall
Thanks, Duncan -- I will take a look.
Take Care,
j
