Public Sub InMemoryExample() ' Description: Sample code showing how an in memory table can be created ' Create Workspacefactory Dim pWorkSpaceFactory As IWorkspaceFactory2 Set pWorkSpaceFactory = New InMemoryWorkspaceFactory ' Create Workspace Dim pWorkspaceName As IWorkspaceName2 Set pWorkspaceName = pWorkSpaceFactory.Create("", "MyInMemoryWorkspace", Nothing, 0) ' Get a handle on Name Dim pName As IName Set pName = pWorkspaceName ' Get a handle on FeatureWorkspace Dim pFeatureWorkspace As IFeatureWorkspace Set pFeatureWorkspace = pName.Open ' Now create a fields object and add some fields to it ' Create Fields object and set the number of fields Dim pFields As IFields Set pFields = New Fields Dim pFieldsEdit As IFieldsEdit Set pFieldsEdit = pFields pFieldsEdit.FieldCount = 2 ' Create objectID field Dim pField As IField Set pField = New Field Dim pFieldEdit As IFieldEdit Set pFieldEdit = pField With pFieldEdit .Name = "OBJECTID" .Type = esriFieldTypeOID End With Set pFieldsEdit.Field(0) = pField ' Create Type field Set pField = New Field Set pFieldEdit = pField With pFieldEdit .Editable = True .Name = "VegType" .Type = esriFieldTypeString .Length = 4 .AliasName = "Vegetation Type Code" End With Set pFieldsEdit.Field(1) = pField ' Create Table Dim pTable As ITable Set pTable = pFeatureWorkspace.CreateTable("MyInMemTable", pFields, Nothing, Nothing, "") ' Create a sample row and add data Dim pRow As IRow Set pRow = pTable.CreateRow With pRow .Value(1) = "WOOD" .Store End With ' Add table to map document Dim pMXD As IMxDocument Set pMXD = ThisDocument Dim pMap As IMap Set pMap = pMXD.FocusMap Dim pStandAloneTableCollection As IStandaloneTableCollection Set pStandAloneTableCollection = pMap Dim pStandAloneTable As IStandaloneTable Set pStandAloneTable = New StandaloneTable Set pStandAloneTable.Table = pTable pStandAloneTableCollection.AddStandaloneTable pStandAloneTable pMXD.UpdateContents End Sub
Dim pRowBuffer As IRowBuffer Dim pCursor As ICursor Set pCursor = pTable.Insert(True) Set pRowBuffer = pTable.CreateRowBuffer pRowBuffer.Value(1) = "WOOD" pCursor.InsertRow pRowBuffer
Signed in members can post, follow updates, and more. New here? Register a free account.
