You can't usually download this. I haven't been able to find it. However, the SDK (all of them, .NET, Java, etc.) are all on the ArcGIS Install CD.
"Installation ended prematurely because of an error.."
General availability for the "ArcObjects 10.4 SDK for .NET" is not until the week of February 15, 2016. Once the SDK is available you would download it from MyEsri (same as 10.3.1).
So for example for 10.3.1 the download would be here (however, you need to log in first):
https://my.esri.com/#/downloads/ArcGIS for Desktop/10.3.1
What flavor of Visual Studio will allow the "ArcObjects SDK for the Microsoft .NET Framework" to be installed? Visual Studio Community 2015 is not supported. The posted requirements for VS software products that are, at the time of this posting, 3-4 years old seems like a real issue because they are no longer available.
Jason,
Which version of the "ArcObjects SDK for the Microsoft .NET Framework" are you trying to install? The requirements for the latest release (10.4.0) can be found here (scroll to the bottom of the section):
ArcObjects SDK 10.4 system requirements—System Requirements | ArcGIS for Desktop
@Wolfgang Kaiser From the requirements link that you linked in your last comment, it looks like 10.4 will be able to use VS Community 2015. Our clients are still on 10.0, upgrading to 10.3.1, so we have to keep pace with them.
Hi, have you found your solution yet? I am facing the same problem my settings are windows8 (64 bit), Arcmap 10.4.1 and visual studio 2013 professional.
I see the same error dialog while trying to install the .NET SDK.
Windows 8, 64 bit, ArcMap 10.4.1 and Visual Studio 2013 Pro is a supported configuration for the installation of the .Net SDK of ArcObjects 10.4. Please double check your configuration and if that doesn't resolve your issue please contact Esri support.
Hello , i need to deploy on my application ArcObjects SDk 10.4 i have arcgis Desktop 10.4 .Any one can tell me how i can to download the SDK ? cause i tried to go on the downloads page (http://support.esri.com/en/Products/Developers/desktop-sdks/arcobjects-sdk-for-the-microsoft-net-framework/10-4 )and i used my account ESRI but when i access to the download page i don't have the access ? any one can lead me please
You should be able to use https://my.esri.com/#/downloads and get all the different files for each installation available under your licence agreement.
Under 'My Organizations' choose 'Downloads', then a product then scroll down to 'Developer Tools'
(oops, I chose Desktop 10.5.1, but 10.4.1 is just underneath it)
If you cannot see the options above, contact your licence administrator to enable them for you, or to download them on your behalf.
