No matter which solution I attempt to deploy I get an error. The error is not very helpful so here I am. Any suggestions?
I'm also having the same issue with failing to deploy any solution with the tool. Did you find a solution yet?
No.
I am having the same issue! Did you ever figure out a work around?
For the first time I tried again and it worked. I was having problems with Python that I just couldn't fix, so I deleted my user profile from windows and basically started over fresh.
"Unable to initialize. Failed to connect to the source portal. Please ensure you provided the correct url and credentials. Failed to add 'solution name'"
I have the same issue. Waiting on ESRI Support response. If I get a resolution I'll try and remember to post
Did you ever get an ESRI Support response on this? I'm getting the same exact error message:
#esri solution
Did you ever get this to work for you?
My workplace has a lot of internet security measures that often cause issues, so I tried deploying from home and had about 50% success.
Finally, I called my regional ESRI rep and he deployed it from within the ESRI mothership. Said this was a heavy network traffic lift, so it was not unusual to have problems...
There can be multiple things that would cause this error. First question I would ask is... Are you currently signed in to your Organization and does the user type that you are logging in with have permissions to publish to the organization?
What version of the solutions deployment tool do you have and what version of Pro are you running? The January 2019 update of the solutions deployment tool introduced support for Pro 2.3. If you're using an older version of the solutions deployment tool with Pro 2.3, this could cause issues.
Also, are you trying to deploy the solution to your Enterprise Portal or to ArcGIS Online?
What type of authentication are you using to access where you are publishing? (Built in users vs. IWA).
Signed in members can post, follow updates, and more. New here? Register a free account.
