ArcGis 9.3 -> 10 upgrade 80040111 COM Error
3224
08-16-2011 11:41 AM
brianrathburn
We recently upgraded one of our desktop applications from 9.3 to 10, we are having some trouble when trying to create a new GxFilterShapefiles(); We are getting
{"Retrieving the COM class factory for component with CLSID {90E9D96D-E647-11D3-A682-0008C7D3AE8D} failed due to the following error: 80040111."
i have read through
http://help.arcgis.com/en/sdk/10.0/arcobjects_net/conceptualhelp/index.html#/How_to_migrate_ArcGIS_9...
which has very good information on doing the upgrade, we added the needed references and the
ESRI.ArcGIS.RuntimeManager.Bind(ESRI.ArcGIS.ProductCode.Engine);
also when trying to set display name field on an ifeature layer we get a similar COM exception.
when searching it seems that the 80040111 error code can be caused by a number of things and so far i have not had any luck troubleshooting it myself.
Any ideas would be greatly appreciated.
Brian
EdgarBejarano
Hello.  Are you both performing product binding (new to ArcGIS 10 and which you seem to already be doing with ESRI.ArcGIS.RuntimeManager.Bind) and initializing ArcObjects with a valid ArcGIS license, either with the IAoInitialize.Initialize Method or the LicenseControl (for Windows Form Engine applications)?  Remember, product binding is to be done even before initializing ArcObjects with a valid license.
brianrathburn
Thanks for the quick response.
I do have the lines below in the application when it loads up.
//ESRI License Initializer generated code.
            m_AOLicenseInitializer.InitializeApplication(new esriLicenseProductCode[] { esriLicenseProductCode.esriLicenseProductCodeEngine, esriLicenseProductCode.esriLicenseProductCodeArcView },
            new esriLicenseExtensionCode[] { });
DebbieAlger
Hi, I am getting the same thing. I have binding actually in twice and it gets hit correctly, followed in debug, but I am still getting that same error on the first AO instance? I am getting quit annoyed at ESRI making this transition such a pain.
Did you ever figure this out???
thx
