Unable to geocode address using ArcGIS World Geocoding Service
1308
01-20-2023 12:22 PM
KoheiAkiba
Hi, I'm trying to geocode addresses on ArcMap using the ArcGIS World Geocoding Service.
Once I sign into my Esri account and input all the data from the Excel Table that's properly connected to the document and hit "OK," I get hit with an error prompt saying that "There was an error trying to process this table."
I made sure to use the right version of Excel when importing the data, and all the addresses are properly segmented and in table form. I'm not sure what the issue is, but ArcMap isn't even able to start geocoding the data before it brings up the prompt.
Let me know if there's anything else I can clarify for this issue. Thanks.
RhettZufelt
MVP Notable Contributor
Have you installed the Microsoft Access Database Engine 2016 Redistributable driver to enable ArcMap to utilize Excel files?
Good test, are you able to add the Excel worksheet to ArcMap with the Add Data button and open it?
Not sure if this is it, but if you can't load/open the Excel sheet in ArcMap directly, then the tools won't be able to use it either.
R_
