Striped issue with fill pattern polygon symbology
1170
12
05-09-2022 03:49 PM
JonathanBarnsley
New Contributor II
Hi there,
I am having some issues with symbology for a polygon layer where the fill pattern has striped irregularities (see image). Recreating the layer has no impact, and it seems to be specific to the standard three dot fill pattern. I have cleared the feature cache. The only thing I have found that helps is if I pull the layer into another blank MXD. Besides recreating a new MDX, which I am trying to avoid, I am not sure what options I have.
Are there any thoughts on what might be causing this?
Thanks a bunch!
RhettZufelt
MVP Frequent Contributor
Sometimes I see this with something wrong with the data.  Could try check geometry tool and repair if reports issues.  I've seen that fix it sometimes.
Though, when zooming in, ArcMap seems to do stuff like that a lot with picture fill in the symbol.
If I edit the symbol and create something similar with marker fill(s), I normally don't run into this kind of issue.
R_
JonathanBarnsley
New Contributor II
Hi Rhett,
Thanks for getting back to me! Tried check/repair geometry but it didn't seem to fix it.
I did try to recreate the MXD using the same template and without a template and found that the issue again in both cases. However, I did notice at some specific scales or with specific dimensions of the map box in design view the striping changed or entirely went away.
Presumably this is an issue with the repeat distance of the pattern fill having some issue at a given draw distance/dimension. A bit annoying and probably no easy fix for a user besides scaling/rearranging until it draws correctly?
JB
RhettZufelt
Jonathan,
It looks like you are using the Historic Site fill symbol?  If so, and you edit the symbol, you will see it is a picture fill symbol.
I have not had much luck using picture fill symbols if I have to zoom in very far.  At some zoom level, the points will start stretching out into lines until they finally just stop drawing.
I normally edit the symbol, switch to marker symbol and play with the layers/offsets/etc. until I get the dot density/pattern that I want.  Then, they will zoom in/out as expected (if there are no geometry issues).
R_
JonathanBarnsley
New Contributor II
Hi Rhett,
Yep, it's based off the Historic Site picture fill. Ah! That may well be the issue.
I will give it a go recreating the same pattern (as it is used as a standard symbology) with a marker symbol and see how it goes.
Thanks for your help!
JB
RobertBorchert
Frequent Contributor III
describe your hardware.
Meaning what are you using for a processor, ram, gpu, etc
have your tried a different fill pattern and a different color.
A good practice is to only use web safe colors for display purposes. But I suspect it could be hardware related.
RhettZufelt
Intel Core i9-10900X, 32Gb, Quadra P2200
Intel Xeon Gold 6146, 32Gb, virtual box with Hyper-V video
Intel Core 97-7700K, 32Gb, Radeon Pro WX 5100
are the three I tested with recently.
You can add every version of ArcMap from 8 to 10.6.1 as these are the only I have tested/seen the issue with.
Suspect when we get to 10.8.1 this summer, will be the same.
Tried every picture fill in the ESRI palette.  A few of them don't go away when really zoomed in, but can't find a picture fill that does not start "mis-behaving" when zooming in close.  They all seem to at least start "streaking" or putting while lines in there or something, though some are better than others.
R_
RobertBorchert
Oops my apologies I didn't see the part where it was a picture fill.
Maybe try creating your own picture to use as the fill and save it as a transparent .png before brining it in.
Have you tried changing the background to a different color?
RobertBorchert
As far as creating a new .mxd
I found issues almost every time I upgraded ArcMAP
A simple way to recreate the .mxd in a newer format, and also more effective than saving as a new version.
Open your .mxd and start a new blank session
make sure all features and groups are visible in the data frame(s)
Open the layouts for both .mxd's
From the old .mxd select all elements in the layout.
Copy and paste into the new layout.
The only cleanup I have typically had when doing this is adjusting the layout elements.
RhettZufelt
Yep, tried different colors.  have not tried to create a new transparent.png to test.
I just chalk this up to one of the "known limitations" of ArcMap, and change from picture fill in the rare occasions I need to zoom in that far.
Highly agree on starting with new ArcMap session.  Even if same version, and want a map with same data, select them, copy/paste to new mxd is way "safer" than Save As option.
As a test, I just copied/pasted all the layers from my working mxd that is 14.5 Mb, saved the new mxd and is 4.6 Mb.
Same data, just shows how much "legacy" info gets kept inside of an mxd (has caused a lot of locking issues in the past as well as it can keep locks to data that is no longer in the mxd.)
R_
