Initial Data Frame Extent
2271
01-04-2021 03:11 AM
OliverIshmael
Is there a way to set an initial default data frame extent e.g. centred on a particular place, WITHOUT preventing users from subsequently choosing to zoom out further, as is the case with the Data Frame Fixed Extent?
Tags (1)
DavidPike
MVP Notable Contributor
What's the scenario? If it's a blank MXD, the DF will move to the extent of initially added data.
Also Setting a custom full extent for your data frame—Help | ArcGIS for Desktop
OliverIshmael
Yes its a blank MXD.
The issue we have is that the initial data added is often our basemapping layer file which covers a much greater area than many users require. Of course we could just create 2 basemap layer files for users to choose between, but i wonder if there is more elegant solution?
Mary_Murphy
Maybe a map template might be of use?
Link: Using map templates
OliverIshmael
While a map template is useful, in essence i was hoping that there was a way to save a spatial bookmark within a layer so that it opened at a specified extent.
Mary_Murphy
Gotcha. Essentially, setting up a predefined area  of interest / location of interest at the layer level, not the  data frame level. Unfortunately, I don't think that is currently possible. The other option may be to request that they add the AOI data first, then the basemap? Make it part of the process?
