I am using ArcMap 10.8.1.
I have noticed that the Voronoi maps are not generated anymore in my version. Anyone having the same problem?
Thank you,
Maria
Geostatistical Analyst?
Identifying local outliers using the Voronoi Map tool—ArcMap | Documentation (arcgis.com)
Is the extension toggled on?
Or do you have an advanced license?
Create Thiessen Polygons (Analysis)—ArcMap | Documentation (arcgis.com)
There are others, if you search on Voronoi or Thiessen in the help
Search Result | ArcGIS Desktop
Thank you Dan, yes I have advanced. I see the points, but the polygons do not appear. I will check the links and see if I solve it.
maybe you have to add the layer... see if it was created first
I just tested this with ArcMap 10.8.1 and they show up for me in the toolbar > Explore Data > Voronoi map. Maybe try changing the color map or a different dataset?
Thank you Curtvprice,
Maybe I changed some settings, because now that you mentioned I also did some earlier this year. I can't see them yet.
