How do I get a specific field name with arcpy?
9737
9
01-05-2021 02:26 PM
Labels (2)
by Anonymous User
Not applicable
I have a geodatabase table with three fields. After creating a list of fields with arcpy, how do I reference just the third field to acquire the fieldname for use in the next arcpy statement?
2 Solutions
DanPatterson
MVP Esteemed Contributor
ListFields—ArcGIS Pro | Documentation
assuming
field_names = [f.name for f in arcpy.ListFields(featureclass)]
third_fld = field_names[2]
... sort of retired...
DavidPike
MVP Notable Contributor
Further to Dan's point, you should probably pass third_fld within a list as the last argument.
arcpy.JoinField_management(fc_in, joinfld1, gdb_table, joinfld2, [third_fld])
JoshuaBixby
>>> l = ["field1", "field2", "field3"]
>>> l[2]
'field3'
DanPatterson
assuming
jrneyulu
This will fail when cursor is fetching mentioned fields only, better to Collect field names from Cursor not from feature class.
DavidPike
What do you mean by 'mentioned fields'?
by Anonymous User
Not applicable
This is similar to the procedure I came up with yesterday after many trials and errors:
third_fld = arcpy.ListFields(gdb_table)[2]
I could get it to print the name of the correct field with:
print('Field is {0}.'.format(thrid_fld.name))
I could not, however, pass the field name into the JoinField tool with:
arcpy.JoinField_management(fc_in, joinfld1, gdb_table, joinfld2, third_fld)
 I'm guessing I am missing something and to simply reference 'third_fld' in the JoinField statement is generating the error:
Runtime error
File "<string>", line 65, in <module>
File "c:\program files (x86)\arcgis\desktop10.8\arcpy\arcpy\management.py", line 6587, in JoinField
raise e
RuntimeError: Object: Error in executing tool
DavidPike
by Anonymous User
Not applicable
I got this to work. A couple of issues - it never worked in ArcMap but did in Pro. Plus I changed the interpreter within Pycharm to ver 3.7. And added the brackets around third_fld.
Thanks everyone!!
Pam
DanPatterson
third_fld ...thrid_fld ... third_fld
Consistency? Is this a copy-paste issue on your pare or is that what you have in your code?
by Anonymous User
Not applicable
Typing issue - the code was correct.
