Failed to add field to the table/feature class
4147
02-11-2021 08:43 AM
JeremyScott
I recently installed 10.8.1 and now cannot add a field to any shapefile. I was able to add one to the first shapefile, but as soon as I tried to add the second I get an error messages that states 'failed to add field to the table/feature class'. I have tried other feature classes and tried exporting a feature class to a new one, no luck. I then uninstalled 10.8.1 and reinstalled and still have the same issue. Everything worked fine while I was using 10.4.
JoeBorgione
Are you really adding fields to shape files or are you adding fields to a geodatabase feature class?  How are you adding the field? With a tool or in arcpy?  Can you provide a screen shot of the actual error the gets returned?
That should just about do it....
JeremyScott
Yes, I am really adding a field to a shapefile. I open the attribute table
and select 'Add Field'. I was just able to add a field to two of my
shapefiles, but on the third I tried to replicate the error and this is
what I get. Doesn't seem to tell me a whole lot. The two feature classes I
was able to add a field, I now cannot -- I get the same error message.
[image: image.png]
Jeremy
JoeBorgione
Yes, I am really adding a field to a shapefile.... The two feature classes I
A shapefile and a feature class in a geodatabase are two entirely different data structures.
Unfortunately you image didn't get attached.  You may want to start a tech support case for this one.
