Default Coordinate System when opening ArcMap
1096
01-13-2022 09:26 AM
rhunley3
Hello Esri Community,
Wondering if there is a way to create a default coordinate system every time I use or open ArcMap.  Currently using ArcMap version 10.8.1.
Thank You.
DanPatterson
MVP Esteemed Contributor
In short, no.  The first layer added to a map set the coordinate system.  In Arcgis Pro, you can define a project template for new projects
... sort of retired...
DanPatterson
rhunley3
Thank you.
