Attribute Table Expression for HTML Popups
993
06-20-2022 12:36 PM
JTLaurente
Hi, I'm using ArcMap 10.8 and trying to figure out how to do this:
I have a .jpg image in my HTML popup which pulls from the Attribute Table. I don't want to have to manually fill in the network location for these images everytime I create a new feature, so I need a way to make an expression such that I can type in the folder location, and then have it pull from the "Name" attribute to fill in the exact filename. That way it will just reference the folder for the images and all I have to do is fill in the name attribute. How can I go about doing this? Thanks!
RobertBorchert
Honored Contributor
make the html the default value for the field
JTLaurente
Makes sense, but then how would I have that changed depending on the name of the feature?
