ArcMap Open Failed Error opening feature class
1514
05-11-2021 03:04 PM
NatNoles
Hi there,
I'm looking for help on fixing an error while trying to add a new feature class into an existing feature dataset called Province.
Error in Arc Catalog while pasting the new feature class called "Rivers" or importing:
Open Failed: Error opening feature class Layer not found [GIS. Communities]
The feature class "Communities" no longer exists. It is not needed. This is a versioning environment using Oracle 12c.
I have tried different things such as re-creating the fc "Communities", I can see it on both sides inside Arc Map and also Oracle SQL. But, when I try to insert the new fc into fd, it doesn't let me.
I did admin database management: reconcile, post, delete all versions, compress, rebuild indexes, analyze, etc.
I also did the diagnose and repair version tables and metadata and they run successful without errors.
When, I run again rebuild indexes, I checked the python script log and that province/state was skipped. Then, I try to do it manually through arcmap. But, it doesn't let me to access it through properties. It looks like the issue is with the index and some broken links. I do need that feature class but I would like to keep the other feature classes.
You may have encounter this error before. I would like to repair it to keep the names of the other fcs. Your help is appreciated.
Nat
RobertBorchert
Honored Contributor
Where is or what format is the feature class in?  Is it a shape file?
