Adding Character to Text Field using Field Calculator
1281
06-08-2021 01:08 PM
KWallin
ArcMap 10.7.1  New to using scripting to help with adjusting formats and require an assist with my syntax. I tried to bring an excel already formatted, but looks like I need to save as DBF4, and this is not available to me.  I'm working with APN numbers, and it would be helpful for them to be formatted ###-###-###.  They are currently in field PARCEL_APN as #########.
DanPatterson
MVP Esteemed Contributor
use Excel To Table (Conversion)—ArcMap | Documentation (arcgis.com)
and see if it comes in properly as a text field.
If that doesn't work, you may need to do a field calculation in a text field using something similar to
(replace  "a" with he field
"{}-{}-{}".format(!a![:3], !a![3:6], !a![6:])
... sort of retired...
DanPatterson
