Add Data from ArcGIS Online/ Add Basemap in active!!
1798
10-01-2021 01:08 AM
Mohamedhared22
Dear All,
I am a student studying the GIS Specliaztion course at the Coursera portal. I got 1-year learning license. but after installing the desktop version ( ArcGIS 10.6) both add base map and add data from ArcGIS online are not active. Can anyone please help to activate these two options?
Tags (1)
JayantaPoddar
Close all ArcGIS Applications.
- Install ArcGIS Desktop TLS Patch for ArcGIS Desktop 10.6.1?
- Ensure your system is connected to internet
- Open ArcMap. If the issue still persists, "Run Connection Test..." from the ArcGIS (Globe) icon in Taskbar.
Share the results of the tests performed. e.g.
 More troubleshooting steps can be found here Troubleshooting issues adding ArcGIS Online basema... - Esri Community
Think Location
JayantaPoddar
Think Location
Mohamedhared22
Many Thanks. Perfect Solution. It worked well.
GeraldBartz
Your problem can be caused by a number of reasons. A good troubleshooting guide is provided at:
https://support.esri.com/en/technical-article/000013300
